is it a welded cylinder or does it have a threaded ot bolt-on cylinder head? There is a reason I'm asking.
Also, what are you calling the rear seal? There is only a piston seal (probably a cast iron piston ring) and the rod seal. So one is inside and the other is at the top. Most of these old twin arm cylinder had welded bases.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
