11 members (Peggy M, klhansen, Wayne67vert, 52Carl, Hotrod Lincoln, Forty9, walter74, HandyAndy, cmayna, 55shaker, TPR57C),
138
3
Mod | | | Forums66 Topics128,114 Posts1,056,282 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#85464 04/24/2004 4:10 PM | Joined: Mar 2001 Posts: 259 Member | | Member Joined: Mar 2001 Posts: 259 | Hi-
The "B" terminal they are talking about is the terminal where the Positive battery cables connects to the starter.
I think you have a mis-print on your instructions......"I'm sure you do". If you connect a wire from the (-) terminal of the ammeter to the gauge (-) terminal your going to fry some wires. That (-) sign should be (+) sign. I think what they mean to say is connect the wire feeding your gauges to the side of the ammeter which will show a discharge when the gauges are on which would be the (-) side of the ammeter but connected to the (+)terminal. Then you'll connect a ground from (-) terminal of each gauge to the cab to ground the gauges.
Joe
