8 members (Otto Skorzeny, MikeE, Wickedbass, MNSmith, 2-Ton, JW51, Maybellene, 1 invisible),
74
2
Mod | | | Forums66 Topics128,042 Posts1,055,597 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Check your shocks. I had a 'wobble' on my '38. I replaced the king pins & checked everything for tight. All checked out good but the 'wobble' was still there. I fiddled with air pressure in the tires but no change. I finally put new shocks on and the 'wobble' went away. It felt like a wobble (side to side shake) rather than a bounce as you would expect from bad shocks but the new tube style shocks fixed the problem for me.
