| | | Forums66 Topics128,153 Posts1,056,842 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2000 Posts: 5,228 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,228 | If you look at the top of the column by the steering wheel, you will see where the diameter is smaller and a small hole has been punched in the tube. The upper bearing/bushing sets on the tang of metal from the small hole, and the small diameter is where the bushing is pressed into. The original bushings (no bearings) is made of a wood type material with some sort of leather like stuff on the inside where the center shaft rides. On top of the bushing is a brass ring with a few ears pressed into the bushing to hold it in place. One of the ears has the horn wire soldered to it and the wire runs down through a hole in the bushing. Its all insulated from any metal. The wire runs the length of the column and exits just above the steering gear on the frame side. http://chevy.oldcarmanualproject.com/1929_54chevyparts/06/395.HTMJoe | | |
