I would say there could be a few things to check. First check for proper tire size for the truck & that all 4 tires are the same size. Having worked in the tire business for several years I have seen people mix tires on duallys not a good thing. Second is to make sure that the rims are correct as well, if the offset of the rim is wrong that could be a problem even with the correct tire size. Make sure that all the wheels are the same as well.
Hope this helps...
"IT IS WHAT IT IS"
1953 Chevrolet 1/2-ton 3100 4x4
In the DITY Gallery
More images in Flickr
1948 GMC 1-Ton (now sold to someone in Hawaii!)
More photo in Flickr
1953 Chevy 1-Ton
