| | | Forums66 Topics128,009 Posts1,055,297 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2008 Posts: 202 Shop Shark | | Shop Shark Joined: Feb 2008 Posts: 202 | I built the bed on the truck a little different than Brad. I first put two 4x4"s across the frame and then put the sides and front panel together and installed the bolts finger tight. Next I installed the rear sill and the cross members. After that I put in the two outside planks(with the mounting holes) with the bed strips. Then I was able to aline the bed with the mounting holes and remove the 4x 4"s and lower it into place on to the mounting blocks. Next I installed the rest of the planks and bed strips finger tight and squared up the bed, then started tightening All the bolts in 3 stages.
Keep the 216's running. 1949 1/2 ton model #1314 (US 3104) Brian
