| | | Forums66 Topics128,047 Posts1,055,532 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#84816 09/23/2006 12:53 AM | Joined: Dec 2003 Posts: 975 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 975 | Two posts in same night on dash board stuff..you guessed it, I am in the process of wiring up my 46 1/2 ton.
I purchased a Jim Carter's harness. Included in the harness is the wire that runs from the ignition switch to the coil. The original setup has it installed inside the armored housing. I took the ignition switch apart and the got as far as the switch mechanism. Does the mechanism pop right out or is there a trick to installing a new wire inside the armored housing? I don't want to destroy the inside of the ignition switch if I can help it...
Long question short...how do I put a new hot lead in my ignition switch without destroying it?
Thanks in advance | | |
