7 members (Paul Mullen, Peggy M, mason86, walter74, Bill Hanlon, Hotrod Lincoln, ndkid275),
63
0
Mod | | | Forums66 Topics128,050 Posts1,055,680 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2012 Posts: 102 Shop Shark | | Shop Shark Joined: Mar 2012 Posts: 102 | Hello, I replaced the push button starter on my 46 truck (has a 235 engine) with a 6 volt foot starter. My question is how do I wire it. Please see picture labeled New Foot Starter. Which wires go connected to the solenoid? I am guessing the positive battery cable, but there are also a blue cable that is coming from the ignition switch, a yellow cable that is coming from the 6 volt alternator and a thicker cable that is coming from the Gauge Instrument Cluster. There are also two bolts on the end of the starter, does anything go connected there? Also a question on the coil does the positive connector on the coil go connected to the ignition switch or to the distributor? Please help Old Push Button Starter New Foot Starter
1946 Chevy Truck Export Blue with Black Trim
Entire Thread
Foot Starter Wiring Problem, Please Help
| mauricioaglr | 04/20/2012 9:58 PM |
Re: Foot Starter Wiring Problem, Please Help
| GWWirth | 04/21/2012 3:05 AM |
| mauricioaglr | 04/21/2012 4:26 AM |
| mauricioaglr | 04/23/2012 5:04 AM |
| mauricioaglr | 04/25/2012 4:43 AM |
| 3B | 04/25/2012 8:49 PM |
| mauricioaglr | 04/26/2012 3:20 AM |
| GWWirth | 04/26/2012 3:48 AM |
| mauricioaglr | 05/03/2012 3:10 AM |
| 3B | 05/03/2012 5:38 AM |
| DADS50 | 04/26/2012 2:49 AM |
| mauricioaglr | 04/26/2012 3:18 AM | |
