| | | Forums66 Topics128,026 Posts1,055,405 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#84455 10/17/2007 4:35 AM | Joined: Feb 2007 Posts: 435 'Bolter | | 'Bolter Joined: Feb 2007 Posts: 435 | Pertronix makes an electronic replacement unit that just bolts into your distributor and does away with the points and condenser. Never have to set the points again and much hotter spark. Give em' a call and they will tell you exactly which part number unit you need and usually under $100. DJ | | |
