I have a 46 chevy it is likely the same. The one through the slit in the center top is the high beam indicator light. It goes to floor high beam switch. The dash lights go to a switch on the bottom right of the dash near the steering column. There is another light over the choke and throttle knobs. That one is on the other side of the switch under the dash.
