Hi from England
Got a problem i need help with please
ive a 54 AD with a 350 with a 1406 edelbrock carb.
When i park up i get a real bad fuel smell under the hood and in the cab, i wonder if the carb is over fuelling?
I have a standard pump but i do not have a pressure regulator on it
Do you think that my fuel pressure may be to high?
The truck runs well apart from a slight bog down on takeoff.
The tank is under the bed so i know it is not this
Will a fuel regulator possibly cure the problem?
Thanks Keith
if it ain't greasy it ain't diddly
