9 members (JW51, Gdads51, SmalltownTRKGuy, HandyAndy, Hotrod Lincoln, 48jim1ton, baldeagle, cmayna, Otto Skorzeny),
74
1
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,049 Posts1,055,634 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2012 Posts: 31 New Guy | | New Guy Joined: Mar 2012 Posts: 31 | thanks y'all!
@3B yes brand new torque converter, i asked for as close to stock as possible. it should have 1600 stall
@roy yeah i pulled out a TH350 and the speed limit was the same i did go ahead and pull the diff cover, they are 3.90 gears. im with you though, i feel like i should be able to hit 60 with reasonable rpms. i know 3.90 gears are not for the highway flyers, but 45/50 is tops and i wouldnt want to drive at 50 for too long.
i will work on the engine as you and scott have suggested. the plugs and wires are a bit worn. i also picked up a vacuum gage, i should have enough line to run it into the cab with me.
thanks again y'all. | | | |
Entire Thread
new transmission, same problem...doh!
| elsangre | 03/20/2012 5:40 AM |
Re: new transmission, same problem...doh!
| Stranger | 03/20/2012 6:52 AM |
| elsangre | 03/20/2012 4:19 PM |
| 3B | 03/21/2012 1:14 AM |
| Roy Rodgers | 03/21/2012 4:13 AM |
| 48bigtrucks | 03/21/2012 4:15 AM |
| Roy Rodgers | 03/21/2012 4:28 AM |
| 48bigtrucks | 03/21/2012 11:38 PM |
| Roy Rodgers | 03/22/2012 3:45 AM |
| elsangre | 03/22/2012 7:17 PM |
| coilover | 03/23/2012 1:42 AM |
| Hotrod Lincoln | 03/23/2012 3:15 AM |
| 48bigtrucks | 03/23/2012 3:25 AM |
| BC59 | 03/23/2012 7:04 AM |
| elsangre | 03/25/2012 2:05 AM |
| 3B | 03/25/2012 5:31 AM |
| Hotrod Lincoln | 03/26/2012 4:21 AM |
| NathanPlemons | 03/27/2012 3:19 PM | |
