8 members (David Bush, Wally / Montana, GRNHydra, Oswald, Guitplayer, NJC, Otto Skorzeny, 2-Ton),
91
2
Mod | | | Forums66 Topics128,060 Posts1,055,838 Members48,427 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | I assume you have the original 15" two piece rim? Don't waste any time or money on them. All you’ll be able to mount on them are bias plies with tubes and flaps. Might even have a hard time finding a shop that will work on those rims. Best bet is to just get rid of them and find a later set of eight lug tubeless rims. There’s a discussion started on that subject every other day here on the forum so you can do a search and start reading opinions on which rim is best suited till the cows come home. There is no definitive one best rim answer for stock rims so be prepared for some confusion. If you have deep pockets then you can have rims custom made to your diameter and width with the proper back spacing for around $100 each. Denny Graham Sandwich, IL
Denny G Sandwich, IL
