1 members (J Lucas),
94
0
Mod | | | Forums66 Topics128,049 Posts1,055,635 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2005 Posts: 1,636 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,636 | Not if his rpms are 500 faster while the speed is ten mph slower.
3:90 with the TH350 should give him 60mph fairly easily. 4:11 may not.
But he does need to make sure the engine is properly tuned and running right first. Then hunt the transmission problems if there is one. If the engine is running right, then he has a gearing problem.
I think if the transmission were not shifting into high gear his rpms would be much higher at 50mph than they are now. Course I could be all wet too. LOL | | | |
Entire Thread
new transmission, same problem...doh!
| elsangre | 03/20/2012 5:40 AM |
Re: new transmission, same problem...doh!
| Stranger | 03/20/2012 6:52 AM |
| elsangre | 03/20/2012 4:19 PM |
| 3B | 03/21/2012 1:14 AM |
| Roy Rodgers | 03/21/2012 4:13 AM |
| 48bigtrucks | 03/21/2012 4:15 AM |
| Roy Rodgers | 03/21/2012 4:28 AM |
| 48bigtrucks | 03/21/2012 11:38 PM |
| Roy Rodgers | 03/22/2012 3:45 AM |
| elsangre | 03/22/2012 7:17 PM |
| coilover | 03/23/2012 1:42 AM |
| Hotrod Lincoln | 03/23/2012 3:15 AM |
| 48bigtrucks | 03/23/2012 3:25 AM |
| BC59 | 03/23/2012 7:04 AM |
| elsangre | 03/25/2012 2:05 AM |
| 3B | 03/25/2012 5:31 AM |
| Hotrod Lincoln | 03/26/2012 4:21 AM |
| NathanPlemons | 03/27/2012 3:19 PM | |
