| | | Forums66 Topics128,010 Posts1,055,298 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2000 Posts: 985 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 985 | I replaced my pump a year or so ago for less then $20.00.
How long did the pump sit while you cleaned the tank and lines. If it was a while the diaphram may have dried out and cracked.
Disconect the output to the carb and place you finger over the fitting. Keep clear of all moving parts and have someone crank the engine. You should be able to tell if you are pushing any air. Or you could just remove the fuel line at the carb and put it(the fuel line) into a clear bottle and crank.
Do you have the fuel filter in the right direction? Is the shut off valve open? Do you have pleanty of gas in the tank?
Good luck
Brian Moore 1949 3100 5 window Deluxe "Today is better than yesterday, but not as good as tomorrow" | | |
