| | | Forums66 Topics128,035 Posts1,055,443 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#83442 09/26/2007 6:07 PM | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | Ross makes about anything you could want in a custom piston. If the current ones are good and you don't want to replace or bore the block I'd certainly mill the head. If it's good it will handle a lot of milling but it would be wise to double check the valve clearances before having it done. I can't advise you on how much to remove to give you a point of compression increase but perhaps others can. I would consult Ross on this as it is their business and they have a lot of experience. | | |
