| | | Forums66 Topics128,019 Posts1,055,343 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#83389 09/27/2007 8:52 PM | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | I can tell you all 235s splash or full pressure used the same head in 1953. The only difference between a 53 head and a 54 and later head is the 53 head is not drilled for the four bolt valve cover.
The easiest way to tell if it is a splash engine is if it has the three screw kidney been cover on the left side of the engine.
See the USA in your vintage Chevrolet! My Blog | | |
