Kurt, I have the reamer and some bushing I could loan you if you want to do the job yourself. Send me a note with address if you want. It's a pretty easy job, hardest part is getting the throttle plate out. I use a standard bench top drill press to do the reaming. Even a worn shaft will tighten up to a point with new bushings.
joe
