| | | Forums66 Topics128,260 Posts1,058,311 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#83201 09/20/2007 4:30 PM | Joined: Mar 2005 Posts: 1,513 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,513 | If you used the flywheel to time it that's your problem. A 1950 flywheel will be for a 216 engine timed at 5 deg. BTDC. A later 235 will want 2 deg. ATDC. Time it with a vacuum gauge for the highest reading.
Curt B.
1952 1300 Canadian 1/2 ton restomod You Tube | | |
