| | | Forums66 Topics128,060 Posts1,055,831 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2005 Posts: 1,636 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,636 | Pop the cap off, pull the number one spark plug. Have someone crank the engine while you hold your thumb over the plug hole. Watch the rotor position when your thumb get blown off the plug hole. Set the distributor as close as you can to where the number one wire will line up with where the rotor was pointing when your thumb came off the hole. Should get you close enough to start. | | |
