0 members (),
93
1
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,055 Posts1,055,782 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | if you can't find someone with a panel/burb sender they can measure up and photograph for you to modify a repro'd pickup sender [post in the parts wanted swap section], your local NAPA or such should be able to get you a universal sender of the correct 30 ohms like thisand welcome to the garage, you'll find lots of help here | | |
