0 members (),
67
Mod | | | Forums66 Topics128,055 Posts1,055,782 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2012 Posts: 24 New Guy | | New Guy Joined: Feb 2012 Posts: 24 | need info on how to get or modify or invent fuel tank sending unit.ive read some about modifying an aftermarket one but i dont even have the original so i have no idea where even to begin,please help,thank you | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | if you can't find someone with a panel/burb sender they can measure up and photograph for you to modify a repro'd pickup sender [post in the parts wanted swap section], your local NAPA or such should be able to get you a universal sender of the correct 30 ohms like thisand welcome to the garage, you'll find lots of help here | | | | | Joined: Feb 2012 Posts: 24 New Guy | | New Guy Joined: Feb 2012 Posts: 24 | thankyou for the kind welcome and info
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 |
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Feb 2012 Posts: 24 New Guy | | New Guy Joined: Feb 2012 Posts: 24 | | | |
