| | | Forums66 Topics128,113 Posts1,056,618 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#83054 09/17/2007 2:54 PM | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | I've not specifically delt with this issue but since it's an overflow device and the break is essentially at the same place as the normal hole in the tube, it would stand to reason to me that leaving it as it is shouldn't cause any harm. Just make sure the oiling passageways into the rocker shafts are clean & open. Your rocker shafts should be full of oil befoe the oil gets to the opening anyway.
