They all use the same 10 spline disc & trans bolt pattern in that era. When you put in a T-5 you need a 14 spline disc. You canuse whatever pressure plat it came with. The last one I did I am useing the original S-10 9 in. clutch disc with the larger pressure plate. It is in my 56 with the 235 engine. It is working real good. I plan on putting in a V-8 engine this year & I will use a larger clutch.
1972 Chevy c10 Cheyenne Super
In the Gallery Forum
