7 members (Shaffer's1950, David Bush, Hotrod Lincoln, JW51, Gdads51, Gray_Ghost, Gib70),
107
0
Mod | | | Forums66 Topics128,051 Posts1,055,735 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#82495 09/04/2007 5:43 PM | Joined: Oct 2005 Posts: 1,317 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 1,317 | You're going to have to do some more research outside of the box...I recall reading that the later model T5's went to a different pattern on the S10's but can't recall what year the change went into effect. It may take a trip to your local GM dealer parts department to get the correct answer. Most of the info available on this and the Inliner's sites, is focused on the pre-88 boxes with the mechanical speedos. I know that some of the electronic speedo(post 88) have the same pattern but I would hate to see you plunk out your money for a box that won't bolt up. Sorry I can't give you a more explicit answer but didn't want you to "assume" it would bolt up okay!!!
Dave | | |
