| | | Forums66 Topics128,052 Posts1,055,727 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#82494 09/04/2007 7:25 AM | Joined: Apr 2006 Posts: 41 New Guy | | New Guy Joined: Apr 2006 Posts: 41 | I have the bell housing all I need is t-5. Will a 1996 t-5 work? I know it has an electronic speedo cable but I am having a hard time finding a mechanical. Also, is it worth considering an s-10 4 speed? I have a 46 pickup with 235 an open drive shaft. | | |
#82495 09/04/2007 5:43 PM | Joined: Oct 2005 Posts: 1,317 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 1,317 | You're going to have to do some more research outside of the box...I recall reading that the later model T5's went to a different pattern on the S10's but can't recall what year the change went into effect. It may take a trip to your local GM dealer parts department to get the correct answer. Most of the info available on this and the Inliner's sites, is focused on the pre-88 boxes with the mechanical speedos. I know that some of the electronic speedo(post 88) have the same pattern but I would hate to see you plunk out your money for a box that won't bolt up. Sorry I can't give you a more explicit answer but didn't want you to "assume" it would bolt up okay!!!
Dave | | |
