| | | Forums66 Topics128,030 Posts1,055,418 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#82294 08/31/2007 2:39 AM | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | Cranking an engine with the starter should develop some oil pressure. If you are worried about starting the engine without the oil pump being engaged you could check it out by pulling the wire from the coil and cranking the engine till you see oil pressure. | | |
