Quote
Originally posted by Tony:
Baldeagle, are you going to install U-bolts to hold the spring and the axle together?
You can't really see it in the pictures, but the triangular mount that is welded to the axle housing extends several inches in either direction above the springs. The U-bolts go over that surface and then around the springs. So they are held on to the springs with U-bolts, it's just not easy to see it in the pictures. If you look at the right spring mount picture, you can see what I mean.
Paul Schmehl CI 6
geek@stovebolt.com
Stovebolt Staff: Geek
