7 members (Donf, Hanks custodian, Cosmo, Gray_Ghost, treegrower, Bill Hanlon, 1 invisible),
105
1
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,080 Posts1,055,956 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | Here is what I'm looking at to do some trading on...
1) 1950 GMC 1-ton w/flatbed. 5-window cab, titled, sheetmetal is good, frame is eaten up from the PO hauling manure on it for over 40 years! Roller. Everything is there.
2) 1950 GMC 1/2-ton with bed, 3-window cab. Homemade divot on RR fender to accommodate a spare tire. No papers, runs with help, roller. Cab is so-so, bed sides are good, front clip is good.
I've been looking for an AD truck for awhile now, and these look pretty good. I plan on using the 5-window cab from the one-ton and building the half-ton int a nice driver.
Questions: What engine would both trucks likely have? *** 228 full pressure engine *** Aren't all of the AD GMCs pressure-oilers? *** YES*** Would both trucks be four-speeds (I did not look at that when I saw them)? *** NO *** THE 1/2 TON CAME WITH A 3 SPEED OR A 4 SPEED. What rear gears is that 1/2-ton likely to have? *** 4:11 *** Where is the serial number located on a '50??? *** DRIVERS SIDE PILLAR.
Thanks in advance!
Patrick | | |
