As for your stuck pedal - it is not uncommon for them to get stuck because the floor panel has shifted. Start by checking that. If the pedal rod is not rubbing there then I would check the pivot point on the block. Mine was stuck pretty solid. Spray it with penetrating fluid and work it back and forth until it is free.
Tim Sheridan
1947 First Series Chevy 1/2-Ton
"Liberty Series" - "Art Deco" - Whatever you'd like to call it.
