Rich, just bust out the porcelin from a sparkplug that fits your engine. Its kinda hard to get out, so you will have to work at it a bit. Then thread a bolt in from the plugwire side. You might be able to rent a tool from your parts house for this job.
Pull a battery cable before inserting the tool, you don't want to change out a piston and rod due to a mishap!
Joe
