0 members (),
79
0
Mod | | | Forums66 Topics128,035 Posts1,055,560 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | There is a pressure-release valve in the oil pump of a 261 engine. In the 261s that I have had, the pressure on the gauge showed steady pressures no matter the temperature or oil I used. I'd expect that to be the case on a newly rebuilt engine that has a good oil pump.
The pressure-release setting produced a reading of 30 psi on one engine and 40 psi on another engine. I think that people have reported a reading of 45 psi on their engines. This variation in settings could be due to different release-valve (spring?) settings in the oil pumps or mis-calibrated oil pressure gauges.
I'd be concerned if the oil pressure reduced below the normal setting - at lower RPM or at higher temperature.
