4 members (Tiny, Otto Skorzeny, 2 invisible),
111
3
Mod | | | Forums66 Topics128,142 Posts1,056,476 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#79806 07/11/2007 10:02 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Most vacuum gauges have a pressure side that you can check fuel pump pressure with. Disconnect the gas line going to the carb & hook it to the gauge. Crank the engine a few times & the gauge will show the pressure. If gas is running over like that it has to be getting by the needle & seat. It is either not seating or too much pressure which I dought. Try this. Pinch the flex line shut with a clamp or vise grip. Start the engine & run it till it uses all the gas in the carb & dies or almost dies. Then take the clamp off & start it again. This will drop the float to the bottom & if their is a particle of dirt it will flush it out. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | |
Entire Thread
Need help, still cant get it to idle
| Purney | 07/10/2007 3:19 AM |
Re: Need help, still cant get it to idle
| atomarc | 07/10/2007 4:20 AM |
| Roy Rodgers | 07/10/2007 5:22 AM |
| Purney | 07/10/2007 4:52 PM |
| carbking | 07/10/2007 5:52 PM |
| waldo53 | 07/10/2007 5:59 PM |
| Purney | 07/10/2007 6:09 PM |
| atomarc | 07/10/2007 6:26 PM |
| Purney | 07/10/2007 6:33 PM |
| carbking | 07/10/2007 7:02 PM |
| Wrenchbender Ret. | 07/10/2007 9:35 PM |
| Purney | 07/10/2007 10:10 PM |
| atomarc | 07/11/2007 12:49 AM |
| Purney | 07/11/2007 1:50 AM |
| atomarc | 07/11/2007 2:24 AM |
| Purney | 07/11/2007 3:27 AM |
| atomarc | 07/11/2007 4:12 AM |
| JiMerit Boltr#43 | 07/11/2007 4:23 AM |
| Roy Rodgers | 07/11/2007 6:41 AM |
| 4ontheFloor | 07/11/2007 7:00 AM |
| TrevsOldChevs | 07/11/2007 8:20 AM |
| Purney | 07/11/2007 2:31 PM |
| Builder | 07/11/2007 5:51 PM |
| Purney | 07/11/2007 6:17 PM |
| Wrenchbender Ret. | 07/11/2007 10:02 PM |
| Purney | 07/12/2007 1:36 AM |
| atomarc | 07/12/2007 2:08 AM |
| Purney | 07/12/2007 2:49 AM |
| atomarc | 07/12/2007 2:57 AM |
| D Sinclair | 07/12/2007 6:28 AM |
| Denny Graham | 07/12/2007 1:49 PM |
| Purney | 07/12/2007 2:20 PM | |
