So that used to be a two piece draive shaft, correct? What kind of drive shaft do you have now?
Truckernix I think you might be onto something here....
I see labluver refers to the driveshaft in singular form.
Apparently drive shafts that are built too long can generate an oscillation and deflect as they spin.
labluver,is the vibration related to engine or wheel speed?
