Are you sure it is not the shifter. Do you have lots of travel when you shift. There is a bushing kit that will fix a worn shifter. I have one that I got because I needed the spring not the bushing. You can have it (free) if you want to try that before removing your trans. Jim Carter has them on page 68.
