2 members (J Lucas, pauld),
123
2
Mod | | | Forums66 Topics128,183 Posts1,057,263 Members48,467 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2005 Posts: 1,513 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,513 | The radiator core support is the "backbone" of the entire front clip and as such I believe removing them will have consequences but you should be able to add gussets or other reinforcement to replace lost stability.
1952 1300 Canadian 1/2 ton restomod You Tube | | |
