| | | Forums66 Topics128,128 Posts1,056,668 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | I don't think so Larry. Those wheel cylinders aren’t machined to take a pipe fitting or inverted flare if that was what you were thinking. Taint like the new ones you know! The banjo’s are available at a bunch of places from most of the vendors catalogs and your local auto parts might have them or be able to get them for you the next day. Also don’t try to reuse the copper gaskets, use new ones or you’ll end up with a leak. DG
Denny G Sandwich, IL
