| | | Forums66 Topics128,007 Posts1,055,278 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#78693 06/13/2007 2:13 AM | Joined: Oct 2005 Posts: 1,317 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 1,317 | I just changed my 54 rubber mounts for urethane mounts...they sandwich the cross member and have nothing to break loose but the grade 8 thru bolt. I would think they would be tougher than the stock 50 mounts and not subject to oil contamination.
One thing I did note....there was no urethane single front mount available that I could find. The urethane mounts are very rigid and don't pull down as easily as the stock rubber mounts. I torqued mine to 65 ft-lbs.
Can't speak to the problems you might encounter with a cross member change but it seems like a viable alternative.
Dave | | |
