| | | Forums66 Topics128,115 Posts1,056,289 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2008 Posts: 337 Shop Shark | | Shop Shark Joined: Dec 2008 Posts: 337 | A factory mechanical fuel pump is completely adequate for a rear mounted tank. The gas gauge sending unit needs to match the gauge. If you go with Dolphin gauges just buy the compatible sending unit. I have seen other threads discussing options to run the stock gauge with a aftermarket sender, but requires an understanding of electronics. Before investing in Dolphin gauges however you may want to do search for user opinions. I've read about several unhappy customers. Here's one I could find easily: http://67-72chevytrucks.com/vboard/showthread.php?t=312195&highlight=dolphin | | |
