You'll need lots of air pressure to keep the valves closed , better to get some cheapo cotton rope and put the cylinder to BDC , feed a long bit of rope in through the spark plug hole and then turn the engine untill it squishes against the valves , remove springs & install umbrella guide seals , replace spring . turn engine , remove rope and go to the next cylinder .
Sometimes the old ways are best (and easiest) .
-Nate
There is no problem so difficult it cannot be overcome by generous application of brute force & ignorance
