I bought a reamer and some bushings form McMaster Carr and did it myself. Once you buy the parts, you can do a lot of them for cheap. The bushings are standard size along with the shaft. To trick is getting the throttle blades off with out breaking the screws. Once thats done, its a easy repair with a standard drill press.
Joe
