Hotrod Lincoln,
Thanks for the help. I bumped the Armature terminal as you suggested and still no juice, but you made a good point about a ground from the gene. to the regulator, so I will make that correction after work Saturday and try it again. I'll let you know how it turns out.
Jessica's Truck
The true definition of insanity:
To do the same thing the same way repeatedly and expect a different result each time.
