| | | Forums66 Topics128,159 Posts1,057,029 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2009 Posts: 554 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 554 | Thanks guys. That's how I did it the first time. Either then, or more likely when I loosened it to remove the line a piece of the copper tube is now stuck in the gauge. Really stuck. I guess if I ever have to remove it again I will take it loose at the block.
The good news is I no longer dread installing and removing the gauge cluster. I am actually getting good at it after 3 times in and out. I read about Alvin and others misadventures in re-doing these old trucks and even though I tell myself I am not going to make that same mistake I seem to end up doing the same things more than once.
Chuck | | |
