hello yerself Grant! grin
the 6cyl engine brackets are slightly different than the V8 , tho they can be modified to work - the 6cyl pins have a different configuration, tho' again, can be modified to be like the V8 pins - OTOH, the complete mount kit is available from the vendors, with all the correct rubber and washers - also if you have a factory 6cyl setup you need the frame brackets that come with the kit, the 6/8 mounts are in a different place
