0 members (),
106
0
Mod | | | Forums66 Topics128,101 Posts1,056,181 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#77578 05/20/2007 4:02 AM | Joined: Feb 2004 Posts: 29,799 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,799 | Denny, those huge condensers Mallory used to be famous for weren't always the cure for point-burning problems. The lagging point would be the one that might burn on the circuit break, since it will be conducting after the lead point opens. If the condenser is over-capacity, the leading point would arc as it closes, completing the discharge. It's pretty tricky, matching condenser capacity to a specific application. Automotive-type condensers generally aren't available in very many different capacitance values. If you chose to find a suitable capacitor from an electronic-parts supply source, you could probably custom-tailor a capacitor to a particular coil/point combination. Jerry
Entire Thread
What for, those dual points?
| Denny Graham | 05/17/2007 5:25 AM |
Re: What for, those dual points?
| atomarc | 05/17/2007 5:36 AM |
| desertdog | 05/17/2007 1:22 PM |
| PAPA ED'S 54 | 05/17/2007 2:23 PM |
| Denny Graham | 05/17/2007 4:02 PM |
| Hotrod Lincoln | 05/17/2007 4:45 PM |
| desertdog | 05/17/2007 5:07 PM |
| 4ontheFloor | 05/17/2007 6:39 PM |
| Denny Graham | 05/18/2007 3:40 PM |
| KENC | 05/18/2007 5:42 PM |
| Hotrod Lincoln | 05/19/2007 12:55 AM |
| delux54panel | 05/19/2007 1:01 AM |
| atomarc | 05/19/2007 2:04 AM |
| waldo53 | 05/19/2007 5:02 AM |
| Denny Graham | 05/19/2007 5:30 AM |
| Hotrod Lincoln | 05/19/2007 2:44 PM |
| waldo53 | 05/19/2007 6:25 PM |
| Hotrod Lincoln | 05/19/2007 6:48 PM |
| waldo53 | 05/19/2007 6:57 PM |
| Hotrod Lincoln | 05/19/2007 7:19 PM |
| Denny Graham | 05/20/2007 3:35 AM |
| Hotrod Lincoln | 05/20/2007 4:02 AM |
| Denny Graham | 05/20/2007 11:47 AM | |
