thanks for the replys ,i guess i should of said in the first post that i have already done the gm oil,and additive plus the figure 8S all with no help it still had a chatter after about 60-80 miles on a left turn!plus we tried an extra bottle of additive per an old gm mechanic ! so i believe i had better tear it apart ,any ideas on tearing it apart? i think all needed is to remove crosspin and gears and pull clutches ? been a long time ?thanks mike
