The split manifolds are attached via the metal "clips" that are held by boths to the cylinder head. If you are installing an Offy intake are well, you will need to do a little modifying of the clips since the flange thickness is different. SEE HERE
I have some pics somewhere of what I did to make it work. Will have to look around to see where they are......
SWEET
1950 GMC 450
1951 Chevy 1/2-Ton
The GreenMachine
