I have a 1952 Chevy panel truck with a G80 axle that is 54.25 inches flange to flange. This is 4 inches less than the original axle. There is no room for the shocks which should be on the outside of the springs, because the wheels/tires overlap the axle by 2 inches. I was thinking of changing the wheels to 15x8 with 2.5 inch backspacing. This would be a -63mm offset. Or, should I use 2” wheel spacers?
The tires are P255/70R15.
