| | | Forums66 Topics128,141 Posts1,056,487 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2009 Posts: 30 New Guy | | New Guy Joined: Dec 2009 Posts: 30 | I have a 1952 Chevy panel truck with a G80 axle that is 54.25 inches flange to flange. This is 4 inches less than the original axle. There is no room for the shocks which should be on the outside of the springs, because the wheels/tires overlap the axle by 2 inches. I was thinking of changing the wheels to 15x8 with 2.5 inch backspacing. This would be a -63mm offset. Or, should I use 2” wheel spacers? The tires are P255/70R15.
| | | | | Joined: Jun 2010 Posts: 188 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 188 | Use the wheels with the 2.5 inch BS. Spacers can be hazardous if not instaled right. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Use the wheels with the 2.5 inch BS. Spacers can be hazardous if not instaled right. I agree with that. If you must use spacers, get the kind that bolt on to the flange, and have a second set of studs for the wheels to mount to.
Bill Burmeister | | | | | Joined: Dec 2009 Posts: 30 New Guy | | New Guy Joined: Dec 2009 Posts: 30 | Thank you for the advice. I ordered the offset rims. | | |
