I have a 1948 thriftmaster 3/4 ton which was leaking oil out of the rear of the propeller shaft.
I am trying to locate a place to buy the replaceable sealing surface on the rear of the shaft.
It is where the rear seal rides behind the bearing. It looks as if it was pressed on but it is worn to the point where the new seal will not ride tightly on the surface.
Any help you could provide would be great.
Thanks in advance,
Kellen
